Nach Update: beim Klick auf das Telefon in der Hausarztliste kommt an einem Client folgende Fehlermeldung.
[OS 15.3.2, tomedo v1.153.0.17] ERROR: [OS 15.3.2, tomedo v1.153.0.17]  [Exception: '[<Hausarzt 0x60001a53e460> valueForUndefinedKey:]: the entity Hausarzt is not key value coding-compliant for the key "kontaktdaten".', exception's stack trace: #0  CoreFoundation                      0000000001A02A2E74 __exceptionPreprocess()
#1  libobjc.A.dylib                     00000000019FD8ACD8 objc_exception_throw()
#2  CoreFoundation                      0000000001A02C7534 _CFBundleGetValueForInfoKey()
#3  CoreData                            0000000001A71418A0 -[NSManagedObject valueForUndefinedKey:]()
#4  Foundation                          0000000001A13D39A4 -[NSObject(NSKeyValueCoding) valueForKeyPath:]()
#5  tomedo                              000000000102EBA618 $s6tomedo34ZSHausarztVerwaltungViewControllerC4call33_14EA48B766E677F408C9684BD7A6D038LL7keyPathySS_tF()
#6  tomedo                              000000000102EBA874 $s6tomedo34ZSHausarztVerwaltungViewControllerC18clickCallTelephone33_14EA48B766E677F408C9684BD7A6D038LLyyypFToTm()
#7  AppKit                              0000000001A3F47454 -[NSApplication(NSResponder) sendAction:to:from:]()
#8  tomedo                              00000000010117C4C0 -[Object sendAction:to:from:]
#9  AppKit                              0000000001A3F47258 -[NSControl sendAction:to:]()
#10 AppKit                              0000000001A3F4719C __26-[NSCell _sendActionFrom:]_block_invoke()
#11 AppKit                              0000000001A3F470C4 -[NSCell _sendActionFrom:]()
#12 AppKit                              0000000001A3F46FC0 -[NSButtonCell _sendActionFrom:]()
#13 AppKit                              0000000001A3F44548 NSControlTrackMouse()
#14 AppKit                              0000000001A3F43F54 -[NSCell trackMouse:inRect:ofView:untilMouseUp:]()
#15 AppKit                              0000000001A3F43DCC -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:]()
#16 AppKit                              0000000001A3F43250 -[NSControl mouseDown:]()
#17 tomedo                              000000000102162E28 -[NSControl(getFirstResponderOnMouseDown) zs_mouseDown:]()
#18 AppKit                              0000000001A3F420F0 -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:]()
#19 AppKit                              0000000001A3ECD6F8 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:]()
#20 AppKit                              0000000001A3ECD3A8 -[NSWindow(NSEventRouting) sendEvent:]()
#21 AppKit                              0000000001A470BA08 -[NSApplication(NSEventRouting) sendEvent:]()
#22 tomedo                              00000000010117A1BC -[Object sendEvent:]
#23 AppKit                              0000000001A4312B04 -[NSApplication _handleEvent:]()
#24 AppKit                              0000000001A3D9989C -[NSApplication run]()
...gekürzt wegen max. Buchstabenzahl...
Gefragt in Bug von (38.5k Punkte)
Wir haben seit dem letzten Update das gleiche Problem
Es handelt sich definitiv um einen Bug.
klick bei "1" funktioniert wie gewohnt.
klick bei "2" in der Adressliste gibt den Fehler.
Noch keine Reaktion seites Zollsoft auf den Fehler ...
Sehr geehrte Herren,
das Problem ist behoben und kommt in der v1.154.0.4
Beantwortet von (93k Punkte)
ok, vielen Dank!
19,376 Beiträge
27,783 Antworten
50,020 Kommentare
32,035 Nutzer
