Hallo liebes zollsoft-Team
Ich bekomme heute Nacht diese E-Mail von Google (siehe unten). Das betrifft das Onlinetermin-Modul von tomedo. Oder? Muss/kann/soll ich hier etwas unternehmen?
Oder betrifft das eher meinen Homepageprogrammierer?
Viele Grüße.
Heiko Durst
Dear Customer,
We have detected a publicly accessible Google API key associated with the following Google Cloud Platform project:
Project My First Project (id: magnetic-energy-343521) with API key AIzaSyDvw4oBT-e6iJbAnXLCxvBfs7MAohZTRE0
The key was found at the following URL: https://fuss.guru/onlineterminanfrage/
We believe that you or your organization may have inadvertently published the affected API key in public sources or on public websites (for example, credentials mistakenly uploaded to a service such as GitHub.)
Please note that as the project/account owner, you are responsible for securing your keys. Therefore, we recommend that you take the following steps to remedy this situation:
  1. If this key is intended to be public (or if a publicly accessible key isn’t preventable):
    • Log in to the Google Cloud Console and review the API and billing activity on your account, ensuring the usage is in line with what you expected.
    • Add API key restrictions to your API key, if applicable.
  2. If this key was NOT meant to be public:
    • Regenerate the compromised API key: Search for Credentials in the cloud console platform, Edit the leaked key, and use the Regenerate Key button to rotate the key. For more details, review the instructions on handling compromised GCP credentials.
    • Take immediate steps to ensure that your API key(s) are not embedded in public source code systems, stored in download directories, or unintentionally shared in other ways.
The security of your Google Cloud Platform account(s) is important to us.
GO TO MY CONSOLE
Gefragt in Bug von (3.4k Punkte)
das hat nichts mit tomedo zu tun. Wenn Sie in den den Quelltext Ihrer Seite reinschauen (Rechtsklick "Seitenquelltext einbinden, evtl muss man vorher die Entwicklertools in Safari aktivieren), sehen Sie, dass folgender Code innerhalb des head-Tags eingebunden ist:
<script data-service="google-maps" data-category="marketing" type="text/plain" src="//maps.google.com/maps/api/js?key=AIzaSyDvw4oBT-e6iJbAnXLCxvBfs7MAohZTRE0&amp;ver=6.1.1" id="candy-googleapi-js"></script>
Beantwortet von (30.4k Punkte)
OK, danke! Dann wende ich mich an unseren Homepagler. DANKE!
18,370 Beiträge
26,632 Antworten
47,748 Kommentare
28,970 Nutzer
