Wenn ich bereits mit Internetmarke gedruckte mittels dem Vorschau-Button (siehe Screenshot) betrachten möchte, erscheint zunächst folgender Fehler, bevor sich das Vorschaufenster öffnet.
[OS 12.2.1, tomedo v1.111.0.10] ERROR: Assertion failed: brief.internetmarke.contentFile.ign_localFileName:  (ZSBriefVorschauPopoverViewController.m:88)
	0   tomedo                              0x000000010eef065b -[ZSBriefVorschauPopoverViewController aktualisiereVorschau] + 1257
	1   tomedo                              0x000000010eeefff2 +[ZSBriefVorschauPopoverViewController zeigeVorschauFuerBriefe:selektion:sender:view:] + 170
	2   tomedo                              0x000000010e3f1219 -[KarteiPopoverBriefBrowserController showQuickLook] + 310
	3   AppKit                              0x00007ff811bdc97d -[NSApplication(NSResponder) sendAction:to:from:] + 288
	4   AppKit                              0x00007ff811bdc824 -[NSControl sendAction:to:] + 86
	5   AppKit                              0x00007ff811bdc756 __26-[NSCell _sendActionFrom:]_block_invoke + 131
	6   AppKit                              0x00007ff811bdc65f -[NSCell _sendActionFrom:] + 171
	7   AppKit                              0x00007ff811bdc5a6 -[NSButtonCell _sendActionFrom:] + 96
	8   AppKit                              0x00007ff811bd9414 NSControlTrackMouse + 1817
	9   AppKit                              0x00007ff811bd8cd7 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 121
	10  AppKit                              0x00007ff811bd8baa -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 679
	11  AppKit                              0x00007ff811bd7f78 -[NSControl mouseDown:] + 678
	12  tomedo                              0x000000010e8453c6 -[NSControl(getFirstResponderOnMouseDown) zs_mouseDown:] + 284
	13  AppKit                              0x00007ff811bd6457 -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 4949
	14  AppKit                              0x00007ff811b4a390 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 2582
	15  AppKit                              0x00007ff811b4975a -[NSWindow(NSEventRouting) sendEvent:] + 352
	16  AppKit                              0x00007ff811b47b28 -[NSApplication(NSEvent) sendEvent:] + 352
	17  tomedo                              0x000000010d93b856 -[ZSApplication sendEvent:] + 7015
	18  AppKit                              0x00007ff811e011a7 -[NSApplication _handleEvent:] + 65
	19  AppKit                              0x00007ff8119c893e -[NSApplication run] + 623
	20  AppKit                              0x00007ff81199c7b7 NSApplicationMain + 816
	21  tomedo                              0x000000010ce27558 main + 6613
	22  dyld                                0x000000011ac314fe start + 462
Gefragt in Bug von (31.2k Punkte)
Guten Tag Herr Dr. Stenger,
danke für die Meldung. Das Problem sollte bald behoben werden. Die Fehlermeldung kann, insofern ich mich nicht irre, sicher ignoriert werden.
(Die Fehlermeldung bedeutet, dass die Datei für die Internetmarke für die Vorschau im Client fehlt. Eigentlich sollte diese vorher vom Server geladen werden. Blöderweise ist der Assert (i.e. die Prüfung, welche die Fehlermeldung erzeugt), welcher auf die lokale Existenz der Datei prüft, vor dem Laden gelandet. Die Fehlermeldung ist entsprechend einfach Schwachsinn und kann ignoriert werden. Wenn man Internetmarken kauft, sind die auch normalerweise sofort geladen (weil man in einem Druck-Vorgang sein müsste, welcher diese braucht), aber nach der (automatischen) leerung der lokalen Datenbank ist dies nicht der Fall.)
Toni Ringling
Beantwortet von (25k Punkte)
19,155 Beiträge
27,534 Antworten
49,542 Kommentare
31,317 Nutzer
