Es scheint ein Problem seit dem letzten Update bei 2 meiner Clients mit dem Laden der Umgebungsdarstellung zu geben:
2022-09-16 20:30:53.634/MESZ ERROR [main]  d.i.startup.ApplicationInitializer.(:)()  Beim Start des Clients ist ein Fehler aufgetreten
java.lang.Error: Could not instantiate Graphics Environment: sun.awt.CGraphicsEnvironment
    at java.desktop/java.awt.GraphicsEnvironment$LocalGE.createGE(Unknown Source)
    at java.desktop/java.awt.GraphicsEnvironment$LocalGE.<clinit>(Unknown Source)
    at java.desktop/java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(Unknown Source)
    at java.desktop/java.awt.Window.initGC(Unknown Source)
    at java.desktop/java.awt.Window.init(Unknown Source)
    at java.desktop/java.awt.Window.<init>(Unknown Source)
    at java.desktop/java.awt.Frame.<init>(Unknown Source)
    at java.desktop/javax.swing.JFrame.<init>(Unknown Source)
    at de.impfsoft.impfdoc.client.base.Constants$2.<init>(Constants.java:154)
    at de.impfsoft.impfdoc.client.base.Constants.<clinit>(Constants.java:154)
    at de.impfsoft.impfdoc.client.base.context.ImpfSoftBeanFactory.lambda$1(ImpfSoftBeanFactory.java:130)
    at de.impfsoft.impfdoc.client.base.utilities.ImpfDocSwingUtilities.lambda$2(ImpfDocSwingUtilities.java:91)
    at java.desktop/java.awt.event.InvocationEvent.dispatch(Unknown Source)
    at java.desktop/java.awt.EventQueue.dispatchEventImpl(Unknown Source)
    at java.desktop/java.awt.EventQueue$4.run(Unknown Source)
    at java.base/java.security.AccessController.doPrivileged(Native Method)
    at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
    at java.desktop/java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.desktop/java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)
    at java.base/java.lang.Thread.getStackTrace(Unknown Source)
    at de.impfsoft.impfdoc.client.base.utilities.ImpfDocSwingUtilities.invokeOnEDTAndWait(ImpfDocSwingUtilities.java:86)
    ... 15 common frames omitted
Ein Löschen der impfdoc und impfsoft Ordner hat keinen Erfolg gebracht, manuel die Java Argumente zu ändern (google sagt: -Djava.awt.headless=true) habe ich nicht hinbekommen, die java Version wurde auch versuchsweise ohne Erfolg ersetzt.
Komischerweise funktioniert es auf anderen Clients problemlos.
Gefragt in Bug von (1.8k Punkte)
Ich hatte dazu am Donnerstag den Support am Telefon. Es hieß dort, bekannter Bug, auf den betroffenen Clients sollte jeweils das Terminal geöffnet werden und einmal folgender Befehlt eingegeben werden:
mv ~/Library/impfdoc/jre-11.0.11-full.jre/ ~/Library/impfdoc/jre/
Danach Impfdoc bzw Tomedo einmal neu starten und es sollte laufen.
Beantwortet von (2.7k Punkte)
Danke für den Versuch, aber an der Java-Version lag es nicht, da habe ich mehrere gewechselt.
Ich habe den Fehler nach nun mehreren Versuchen selbst lösen können:
Durch manuelles Startes von Impfdoc kam folgender Fehler:
2022-09-18 23:55:47.272 java[2651:137628] *** Assertion failure in void set_surface_colorspace(CGSConnectionID, CGSWindowID, CGSSurfaceID, CGColorSpaceRef _Nonnull)(), NSCGLSurface.m:118
ERROR:java.lang.reflect.InvocationTargetException
Anhand dessen habe ich herausgefunden, dass mein gewähltes Farbprofil des Monitors falsch ist (das war noch auf ein zuvor angeschlossenen Monitor eingestellt).
Unter dem korrekten Farbprofil funktioniert es (welches mit SpyderX, einem Monitorkalibrierungsgerät von datacolor erstellt wurde).
Beantwortet von (1.8k Punkte)
Hallo Herr Wüllner,
vielen Dank für ihren Beitrag im Forum. Das Problem war uns bisher tatsächlich nicht bekannt. Vemutlich können wir da nicht direkt etwas tun, da der Fehler direkt aus dem Java kommt, ich nehme den Fall aber in unsere Supportdatenbank auf, damit wir das nächste Mal schneller helfen können.
Herzliche Grüße
Christian Fischer
20,202 Beiträge
28,685 Antworten
51,968 Kommentare
35,002 Nutzer
