Hi,
der Tomedoclient stürzt reproduzierbar ab, wenn ich probiere, was in die EPA zu laden:
[OS 13.6.1, tomedo v1.154.1.10] ERROR: Assertion failed: [ZSTIConnector activeEpaStufe] == 3:  (ZSTIConnector+EPA.m:126)
0   tomedo                              0x000000010f8489db +[ZSTIConnector(EPA) setUpVauKanalWithCompletionHandler:WithFailHandler:] + 335
1   tomedo                              0x000000010f848274 +[ZSTIConnector(EPA) setUpTIServerWithCompletionHandler:andFailHandler:] + 145
2   tomedo                              0x000000010f85befa __90+[ZSTIConnector(EPA) provideAndRegisterDocument:andMetaData:forPatient:onComplete:onFail:]_block_invoke + 264
3   tomedo                              0x000000010f606896 +[TIConnector(MacOS) contextWithFallbackForTIConnector:andTIMandant:andNutzer:onComplete:onFail:] + 412
4   tomedo                              0x000000010f6065d2 +[TIConnector(MacOS) contextForNutzer:onComplete:onFail:] + 1157
5   tomedo                              0x000000010f847f61 +[ZSTIConnector(EPA) getConnectorAndContextForEPAOnComplete:onFail:] + 264
6   tomedo                              0x000000010f85bd8e +[ZSTIConnector(EPA) provideAndRegisterDocument:andMetaData:forPatient:onComplete:onFail:] + 311
7   tomedo                              0x00000001120a9027 $s6tomedo28ZSEPADocumentTransferHandlerC6upload9documents3forySayAA0B12WithMetadataCG_So7PatientCtF + 1559
8   tomedo                              0x000000011206cb86 $s6tomedo29ZSEPAMetadataWindowControllerC13performUpload33_C014D1C025151182881D8DD6F029F9EBLLyyypSgF + 134
9   tomedo                              0x000000011206ccdf $s6tomedo38HunderFallStatistikTableViewControllerC21pasteRowIfNotExistingyyypSgFToTm + 95
10  AppKit                              0x00007ff8203fb42c -[NSApplication(NSResponder) sendAction:to:from:] + 323
11  tomedo                              0x000000010fb764d9 -[ZSApplication sendAction:to:from:] + 90
12  AppKit                              0x00007ff8203fb2b0 -[NSControl sendAction:to:] + 86
13  AppKit                              0x00007ff8203fb1e2 __26-[NSCell _sendActionFrom:]_block_invoke + 131
14  AppKit                              0x00007ff8203fb0eb -[NSCell _sendActionFrom:] + 171
15  AppKit                              0x00007ff8203fb031 -[NSButtonCell _sendActionFrom:] + 96
16  AppKit                              0x00007ff8203f7ee5 NSControlTrackMouse + 1816
17  AppKit                              0x00007ff8203f77a9 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 121
18  AppKit                              0x00007ff8203f767c -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 606
19  AppKit                              0x00007ff8203f6ac0 -[NSControl mouseDown:] + 659
20  tomedo                              0x0000000110fbfb2a -[NSControl(getFirstResponderOnMouseDown) zs_mouseDown:] + 328
21  AppKit                              0x00007ff8203f4f9d -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 4330
22  AppKit                              0x00007ff82036c7d7 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 404
23  AppKit                              0x00007ff82036c427 -[NSWindow(NSEventRouting) sendEvent:] + 345
24  AppKit                              0x00007ff82036ae01 -[NSApplication(NSEvent) sendEvent:] + 345
25  tomedo                              0x000000010fb71f2e -[ZSApplication sendEvent:] + 1482
26  AppKit                              0x00007ff82062574e -[NSApplication _handleEvent:] + 65
27  AppKit                              0x00007ff8201fa7ad -[NSApplication run] + 623
28  AppKit                              0x00007ff8201ce9a1 NSApplicationMain + 817
29  tomedo                              0x000000010eaad73f main + 5879
30  dyld                                0x00007ff81cd3941f start + 1903
Es gab Fehler beim Hochladen eines Dokuments:
Sie haben nicht die Befugnis auf das Aktenkonto zuzugreifen. Bitte lesen Sie die Versichertenkarte ein oder bitten Sie den Versicherten der Praxis den Zugriff zu erlauben.)
Gibt es da schon eine Lösung?
-js
Gefragt in Bug von (6.2k Punkte)
Lieber Kollege Smid!
Siehe fett gedruckter Teil ...
Ist beides frisch eingelesen. Testweise von einer MFA...und einen Absturz sollte das nach meinem Verständnis nicht produzieren...
-js
Hallo Herr Smid,
die Meldung besagt, dass bei Ihnen die ePA Sufe 3 nicht aktiviert ist. Bitte gehen Sie in die tomedo Einstellungen auf Praxis -> Kartei und stellen die ePA Stufe 3 ein. Nachdem Sie die Stufe eingestellt haben, müssen Sie die Versichertenkarten erneut einlesen bis die Meldung erscheint "Berechtigung erteilt bis <Datum>". Erst dann haben Sie Zugriff auf die ePA des Patienten und können Befunde hochladen.
Jacqueline Geis
Beantwortet von (2.1k Punkte)
20,114 Beiträge
28,587 Antworten
51,802 Kommentare
34,595 Nutzer
